rickjames80
- Aug 14, 2010
- 3
Hey guys. Im working on a 64 starflite 90hp. Looking through the carb there are tubes that you can see. I believe they are the high speed tubes? The lowest one dumps gas as soon as you pump the fuel bulb up. I thought the float was stuck. I took off the carb bowl and sure enough the float in that bowl was stuck. So I cleaned the bowl and needles and seats made a new gasket. But when I put it back together, same result. Am I missing something? Is there anyway fuel can get into these tubes just by pumping up the fuel bulb?
Thanks in advance
Thanks in advance
