Uxboat
- Nov 14, 2006
- 75
Hi,
I have a 1977 Mercury 500 50 hp outboard,with no compression on the 3 rd cylinder down.Debating what to do with this animal as I worked the problem backwards trying to get it to rev up under load.First I changed the impeller,gear oil then the plugs and finally rebuilt both carbs and fuel pumps.Also one coil before I did the all important compression test.
So if I remove the side cover can you I see the side of the pistons ? I borrowed a Rigid SEE SNAKE but it was too large to enter thru the spark plug hole.From the manual I have looks like the cylinder head and block is one,is that correct ?
Thanks Mike
Thanks Mike
