take the cover off the motor, there is a switch that sits by your throttle cable and it has an arched piece of metal under it that moves when you move the throttle. the switch is ajustable, put it in neutral and adjust the switch so it is sitting in the middle of the arched piece, the button on the switch should be pushed in at that time, then you should be good. sorry tryed to explain the best i could.
