Model# VWB19073A Serial# 56XC13486
Picked up at a garage sale. I believe it was made by Chrysler. Tested it in garbage can and had it running for a bit. Water was coming out from back hole so it appears water pump is working. I want to replace regardless (wasn't started in 10 years). It stopped running and I could not get it started without starting fluid. I may have pumped the bulb too hard so I'll relieve the pressure and try again.
I'm looking for a good supplier for parts (web based or phone). Any suggestion is greatly appreciated. I'm thinking of purchasing a fuel pump kit, water impeller, and lower unit seal kit (if available). Everything else seems to be OK (so far).
I'm also having difficulty loosening the screws to drain the lower unit. I'm thinking of heating the screws?? Any other suggestions??
Besides the blisters on my fingers from pulling the starting cord, I'm having fun with this project and hopefully have a nice motor when I'm done....
Keith
Keith
