I installed a 2nd battery. The spot and the battery switch was alrady there just had to drop in the battery
After using it I found out that it is not being charged by the alt. How do I hook it up so it charges the 2nd battery also?
I have a 5.7 OMC with the 3 wire alt.
Heres a pic of the back of the alt. I assume its the thicker orange wire that charges the battery right? If so, how should I hook this wire up to the battery?
Is it safe to just splice into the wire and run one to the second batt?
