OK---just in case I get my overheating issue worked out---problem #2--Have a hard time gettingthis boat on plne--The mariner 225 efi magnum should jump out of the hole with two people in it but it takes me a LONGGG time to get it out. Before my encounter with a large rock I had a 4-blade stainless 25p that was ported around the hub for exhaust--Had problems then so I went to a 23p that is not ported---Cant hardly get on plane with just me---Mechanic says it DYNOS fine and it runs great on muffs but put it under a load and it is a DOG---New plugs--Coils all test good--Going to test the 40 psi fuel valve tommorow and change fuel lines and filters ---Other than that??? any ideas out there???
