I'm sure this will fall under the category of "Stupid Questions" but figured I might as well ask...
I have an '85 85HP Force outboard (3cyl). The issue began with losing power. It seemed to run OK at idle, but increase the throttle and it loses power. Checked the plugs and found #3 didn't have a spark. At first, thought the coil was bad. Tried connecting it to a different CD-Unit, however, and it sparked fine. After reconnecting coils to correct CD-Units, now only have spark on plug #1. (Coils 1 & 2 are on CD-unit 1 and coil 3 is on CD-Unit 2).
Tracing the wires we discovered that the yellow wire that runs from the stator to the second CD-Unit has been burnt severely right were it connects to the stator. So, my stupid question of the day is, does it matter where on the stator the wire connects? Specifically, what I want to know is can I simply splice this yellow wire to it's counterpart yellow wire that goes to the first CD-Unit?
While I do realize that the BEST solution would be to buy a new stator, I would like to repair it (if possible) to save $$$.
Any ideas? Thanks!!
Stator part# 176-5095 (CDI)
Any ideas? Thanks!!
