I recently replaced the starter on my 96 Mercruiser 5.7. The first time I tried to start it I got a click... and then nothing. I presumed I must have mis-wired so I changed what I thought was wrong and the engine fired right up. Except I noticed that the volt meter which normally reads about 14 was now reading less than 12 and when I rev the engine the gauge goes down instead of up. Also, the choke is not opening up the way it used to. It opens a little initially and then slowly closes until the engine chokes out. When I run 12 volts directly to the choke lead it opens just fine.
Everything was fine before I changed the starter so I presume that's where my problem started. Anyone have any ideas what I did wrong?
