hey boats been down a while need some help. I have a 1996 bullet with 200 Evinrude was having trouble with the tilt and trim was not working. worked fine on trailer got it in water motor was turning but engine just barely going up or down and at full throttle the motor seemed to be pushing up out of the water and some fluid loss at top of main cylinder.So i figure rebuild needed I get a kit and a friend who has worked at a hydraulics shop rebuilds it now it will not lift at all has fluid and the motor is turning fine but know movement at all. The friend took it back apart said everything back the way it was and he was clueless I took it apart everything looked in place Im not sure seems like there is some combination to get the fluid to the right spot to start pumping but ive tried several different combinations
