Battery snap top box: Compression gauge, 2 spark plugs, 1 water pump impellar, 1 t-stat w/ gasket, 3' of fuel line, 8' of wire, hose clamps, fuses.
Small socket set, small wrench set, adjustable wrench, slip joint pliers, phillip and flat blade screw driver, WD40, tube of marine grease, liquid electrical tape
