greenhornet97
- Dec 21, 2008
- 11
Hi Guys, I am going to change the fluid in the lower gear case of a 3 cyl 70 hp 1974 evinrude mechanical shift motor. I need to know how much 80 - 90 weight marine lube I need to pump in from the bottom drain screw .Also, should the motor be straight up and down or is it ok to have the motor tilted up/forward on the boat while I am filling up lower unit with the lube ? Thanks in advance, Vinny
