Hello,
I have a few questions. First is what fuel to use right now i have been using 87 with a 50 to 1 mix is this wrong should i be using 91 with the 50 to 1 or 25 to 1. will this lower the carbon build up. And the second is the fuel connection on the tiller arm leaks when I prime the bulb to rock hard is this normal. I have replaced the female end do I need to replace the male side and if so whats the part number. The reason i ask these question is becuase it seam to have a little sputter about 2 sec long about every 7 mins. I rebuild the carb. done pressure checks 90 with only 5diffrence.
