Making an adapter for Dial Indicator from Spark Plug
SeaKaye12
Sheesh...I know this must have been explained dozens of times...but a search is not giving friendly results right now....
I want to take a spark plug and drill it out to create an adapter for a cheap TDC Dial Indicator.
Porcelain is a challenge to drill through.
What sort of drill do I need?
Is this worth it? Can I but one cheap somewhere? The cheapest that I've found is this one:
http://www.micro-touch.com/html/tdc_dial.html
Hopefully one of you can walk me through the drilling procedure ?
Thanks, Chuck
AlTn
Re: Making an adapter for Dial Indicator from Spark Plug
Chuck...google..Pete's RD 400 blog homemade 2 stroke timing kit..I think that's what you saw
SeaKaye12
That's step by step alright....I'd never seen that page but thanks for the reference to it.
Now I can go to Harbor Freight and get a cheap (lets hope it's just inexpensive...but I imagine it will be **CHEAP**) dial indicator. For some reason the really cheap ones don't seem to come with the spark plug adapter...but now I'm all set with my home-made one.
Thanks so much for the reference!
Chuck
Craig-
A pencil will find TDC with no more disparity than the timing pointer is accurate.
wilde1j
A machinist supply house should have spark plug adapters for < $10. I bought several a few years ago in NJ.
