will a prop from a 1978 898 drive fit a alpha 1 outdrive is the diamater the same????
B bigboat Cadet Joined Jul 15, 2003 Messages 11 Jul 22, 2003 #1 will a prop from a 1978 898 drive fit a alpha 1 outdrive is the diamater the same????
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,448 Jul 23, 2003 #2 Re: Pre Alpha Outdrive? All Mercruiser props will interchange......<br />Except the bravo IIIs twin props....<br />Mercury outboard props from the 4 1/2" gearcase motors(V6s) will Also fit...
