engine swap 350
finer things
hi guys swapping 350s in my sea ray monaco, forum is great ,my question the new (used) 350 was from inboard so a lot has to be switched over bell housing, pulleys, power steering etc. my question , the oil pan in new motor is considerably bigger I would like to use it but I dont think it will fit in boat if i do switch it is everything the same inside, in other words will old oil pan fit new motor or is something different
EddiePetty
Re: engine swap 350
...the larger (and usually deeper) pan may have a windage tray and certainly the oil pump will have a longer pick-up tube. The bolt pattern should be the same but that too depends if both blocks are one or two piece main seal.
finer things
Re: engine swap 350
thanks eddie they are both 1987 260 hp the new one is slightly deeper hard for me to describe but it doesnt angle up till a few inches before end of oil pan where the old one angles up in the middle. I would like to use the new one if it fits but if it doesnt what do I have to do to make old one fit
EddiePetty
Re: engine swap 350
...... I would like to use the new one if it fits but if it doesnt what do I have to do to make old one fit
Just keep the oil pump pick-up's matched to their pans and you should be alright.
scoflaw
Ensign
Re: engine swap 350
If the new pan is deeper, and you suck your oil from the top, you'll leave a lot behind
finer things
Re: engine swap 350
one more question why if these 2 motors are the same make and same year is one oil pan bigger than the other the new one (used) is bigger than the old one I would love to use the new oil pan if it will fit in the boat but I am just curious why they are different
Re: engine swap 350
Ayuh,.... Anything beyond the basic Long Block is outfitted with whatever parts that are needed for whatever application that is wanted...
finer things
Re: engine swap 350
the new (used ) oil pan is bigger does that necessarilly make it better and if it will fit in the boat should I use it
