I have a single 350 MAG MPI with a Bravo III drive. I recently learned of the adjustment you can make by flipping the trim limit pin to allow a more aggressive angle to help with your boats whole shot (if it is in the aft position). Well since my pin was in fact in the aft position I did the flip and now she takes off very well. However, I also messed with the setting on both port and starboard trim switches (aka "puck") on the drive and now she is running 400 RPMs over where she should be (should be 4800 - 5000 and now running at 5600 at WOT if I allow) and also dropped approx 11 MPH at WOT. Prior to any adjustments she was running 38 MPH @ 4800 RPM and now I am pressed to hit 27 MPH @ 5000 RPM.
My question is does anyone know the proper procedure for adjusting the pucks? I know the port side is the sending unit and probably the cause of my headaches. Do I adjust the puck counterclockwise or clockwise or is it different per application?
Thanks!
Thanks!
