Woodbinekeith
- Sep 1, 2009
- 86
I'm just now learning about electronics and see this as a challenge. I'm looking at the minimum gauges/appliances - lights, horn, and a new bilge pump (draws 5 amps/10amp fuse). The dash has a Tach, Speedometer, Fuel, and a hole for one more gauge (maybe was a trim indicator). The instruments are all wired in at present. The wires are a mess at the stern although up front looks reasonable.
Looking at buying a bus bar that could have fuses inbuilt and will check whatever else is out there for circuit breakers. Currently, there is some kind of a buss bar up front but judging from the year, new is probably better. The previous owner told me that all the instruments had been working.
What size of fuse would be best for the bus bar in a boat this size - or is it all circuit breakers now? Or is this even needed. I'm trying to not get a whole bunch of wires going to and from the battery.
The motor is a 1990 90hp Merc and has the wiring set up for a tach and a small 6" rubber tube sticking out from the leg (must be for the speedometer?- so may as well use them).
The battery is located about 12' from the dash so what gauge of wire would be the best to run from +ve buss to positive battery and from -ve bus to negative battery. I think I have used 12 but perhaps this might be light?
The bilge will be hooked up from the existing switch via the bus bar and fused with a 10 Amp inline. What gauge wire should I use for this (it draws 5.6 amps).
What gauge(s) are generally used for the other instruments?
Information/thoughts on the above will be greatly appreciated and I will continue my readings
