Old SHOKAN
- Aug 9, 2010
- 5
Hey folks ... I need help ... I have a 1978 merc inline 6 .. problem started with stuck float on carb #2 ... or so i thought ... symptom was lose of power(ignition failure) on cylinder 3 and 4 (plenty of spark) and gas spitting from carb #2. Rebuilt carb ... replaced plugs .. cylinders 3 and 4 still seem weak ... went out on river .. engine now has no low end ... top end is fine. Tried setting idle on carb two (from 1 1/2 to 2 1/4 ) ... no luck .. back home ... checked compression .. all 6 cylinders in 130-140 range... swapped carb 2 with carb 3 .. ran with muffs ... still no power on cylinders 3 and 4 .. pulled plugs ... OUCH .. water (milky substance) on plug #3. Rest look ok. Forum posts pointed at possible water jacket leak .. installed new water jacket cover and all 3 associated gaskets ... still have water on #3.
Question #1 ... is the power (ignition failure) on cylinders 3 and 4 due to lack of compresson at low rpm's due to a reed problem??
Question #2 ... does the water leak on #3 indicate a cracked block or cylinder head or could it possibly be sucked in through exhaust ports due to reed being stuck open .
