My 93 115 seems to have an abnormal amount of fuel/ oil leaking out of the engine. The fuel seems to be blowing out the air intakes for the carbs. The original oil injection electric fuel pump has been replaced with an older mechanical fuel pump with it was converted to pre-mix (done before I bought). There is a conversion electric fuel pump for disabled injection systems its about $250.. So the question is: Is it likely that the mechanical pump produces too much pressure and blows excess fuel out the carbs? Or is it Likely that I need carb work?
