Could use a little help deciding what's needed for my 85hp Force L-Drive. Picked up the Capri very cheap and the guy didn't know if it would run. Appears it was stored for about 6 years mostly indoors. Starter was bad, fixed. Gas seemed ok, but I drained it anyway. Starts right up with choke, but misses every few seconds. Worse as I add power. Trigger is jammed up won't move. Broke the tab off trying to free it. Trying to find a puller to get the flywheel off. Haven't bought a new trigger because I'm worried motor has too many issues. Would a frozen trigger cause it to miss? I removed and cleaned the carbs, but frankly they looked clean to start with. Plugs looked fair - ordered new ones. Almost seems like the engine misses are hydrolock events, but it did it when the earmuffs fell off too. No evidence of water in the cylinders and all have 130 lbs compression +/- 3lbs. Too rich maybe? Is 130 compression ok for this motor? I have a service manual, but it doesn't really tell me what to test - just how. Can I troubleshoot the engine running dry for short bursts? I'm replacing the impeller anyway - if I can get it running well.
