Re: burning valves
cam is stock heads are stock. we are putting in a thicker head gasket
to reduce comp ratio average compression was 175-180
The stock mercruiser head gasket is think. Unlikely to be able to go more than another 0.010 thicker. You need a much larger change than what a head gasket can do. Going to 76cc heads still leaves you higher compression than the stock 350. A custom cam might help reduce the dynamic compression.
A compression test does not measure compression ratio. You want to be down around 9.0:1 with non-vortec heads.
PS: I ran some numbers in a compression calculator:
Enter Cylinder Bore Size: 4.030"
Enter Piston Stroke Length: 3.75"
Enter Head Gasket Bore Diameter: 4.040"
Enter Compressed Head Gasket Thickness: 0.041"
Enter Combustion Chamber Volume In CCs: 64
Enter Piston Dome Volume In CCs Negative For Dished Pistons (Use '-'): 0
Enter Piston Deck Clearance Negative If ABOVE Deck (Use '-') : 0.026
CR= 11.04:1
Going to a thick 0.061 head gasket only gets you to 10.53:1
76cc heads and 0.061 head gasket gets you down to a manageable 9.3:1
The 11:1 compression is probably the root of your starter kick-back issue, which you had to set the timing just right to turn over the engine.
