gas system additives???
orion208
I have a cuddy with a 4.3 volvo penta 2bbl carb.Would it be ok to put some carb/gas system cleaner in the fuel as routine maintenance as one would for a car or is a boat different in this regard.Thanks :confused:
pburchett
Re: gas system additives???
Ok to use :) , just do not forget that it can unlodge junk, gunk, varnish and such :eek: . This can clog a filter :( if the tank has not had any of this put into it of a while or ever :confused: . <br /><br />I use the concentrated stuff one tank before I change filters. :)
orion208
Thanks I will do that then change filter.
