Hi. I have a 1995 2.5 liter carburated engine. Ran fine going out to fishing area. Trolled with kicker.Then started up main engine. Started ok put in gear and died. Tried starting several more times, would not restart. Back to dock with kicker and found a rope around prop. Removed rope. Next mourning engine started fine but was missing and died at idle. Back home checked compression. All cylinders were 110-115lbs. Reinstalled plugs and started. Pulled number 1 plug wire miss was worse, pulled number 2 engine died. Number 3,4,5,6 did not seam to make a difference. Also smoking and oil out exhaust. Can a two stroke be flooded this bad? Any ideas. Thanks
