chaparall villain 2
- Jul 15, 2010
- 129
ok i need some external advice here ... i am trying to help a friend out and i have done some work on his boat ... he was having problems 4th of july week and told me after he went out and ran the boat for about 15 minutes it would bog and then die ... ran fine prior to that and when he would let it set for about a half an hour it would start back up and run for a while again before dieing again ... i took it to work and pulled the carb apart ... it had a little sediment in the bowl but not bad i cleaned it checked the float and the accelorator pump and all seemed fine .. pulled the anti siphon valve and it seemed to be working fine ... drew about a gallon of gas through the fuel line with a pump and looked for water settling in the fuel and there was none ... fuel smelled fine ... pulled the tube from tank and it was clean as a pin ... so i went to ignition system ... replaced points and condensor with electronic conversion set .. replaced coil and checked voltage there .. it was fine .. i didnt replace the fuel pump because i figured with a mechanical either they work or they dont ... no fuel in return tube or oil to indicate pump failure ... we took it back out yesterday and still dies after running for a while... the carb seems to be drawing fuel thru the main orfice when throttled up at first then it seems to slack off ... i removed the anti siphon valve and it did the same thing ... any ideas ... thanks in advance
