I have a 1995 50HP 4 Stroke with a bad steering arm. I noticed one of the bottom yokes was cracked when I replaced my water tube gasket so I decided to replace the arm altogether as I am sure that the added stress on a single yoke will eventually lead to failure.
I have removed the powerhead, lower unit, and adapter plate. I also removed the retaining ring. I was kind of hoping that the arm would magically drop as I pried the ring off but there is no such luck. The factory manual has no info on this procedure.
Am I missing something or should I just get a dowel and a deadblow hammer tomorrow and beat the tube out of it?
