Re: Draining gas tank
I just went through this earlier this week.
Do you have access to the tank? If so, remove the sending unit, and you can siphon from there. I had to do that, and was even able to 'aim' the hose to the very back of the tank. I figure I got about 99.5% of the fuel out.
If you don't have access to the tank (without cutting the floor open), you can tap into the fuel line where it makes its first connection (fuel/water separator in my case), and hook up an electric fuel siphoning pump to the line, and get it out that way.
If you have a primer bulb, disconnect it at the discharge side, connect another line to it, and you can pump itout that way. This will take the longest amount of time and pumping, but it will work.
If you don't have a primer bulb, now might be a great time to add one.
BTW, how did you confirm water in the tank?
HT32BSX115 types faster then me.
