Re: 7 HP Seaking Starter Help
They go under the pawls, one end hooked to the flat plate, the other end hooked to the pawl. When properly installed, they hold the pawl inward toward the nut. When the motor starts, centrifugal force throws the pawls outward against the spring pressure, thereby dis-engaging the starter.
With that information, look at and you'll figure it out.
