Re: 12v to 24v Trolling Motor fuse problem
I stand corrected -- it is one of the black wires you don't need. (Fingers going faster than the brain.) One of the red wires will be used where I show an orange wire. If you go back and read my previous post you will see where I described two different 12/24 volt systems. While your boat was wired for a bow panel that included a 12/24/RUN/CHARGE switch, yours does not have that feature (at least you have not answered my question about that). That system required separate wiring of each battery to the bow panel. Since your motor has a three wire connection, you only need three wires from the batteries. 1 for 24 volts, 1 for 12 volts, and one ground. Count them in my diagram. If Minnkota wants 24 volts on the orange wire, make the red wire in my diagram orange (or pretend it is). If they say 12 volts is on the red wire, then make the orange wire red. The fourth wire in this system is not needed.
Wiring need not be a mystery. Start at the positive post of the battery on the right. That post is the one that will deliver 24 volts to the receptacle. So if Minnkota wants that to be orange, pretend it is and use one of the red wires. Make sure the other end of that wire goes to the terminal on the receptacle that will feed the ORANGE wire on the trolling motor plug. OK - one down a couple more to go. Now prepare and run a jumper between the POSITIVE terminal on the battery on the LEFT, and connect it to the NEGATIVE terminal of the battery on the RIGHT. Now connect the remaining RED wire to the POSITIVE terminal of the battery on the LEFT and run it to the terminal on the receptacle that matches the RED wire on the trolling motor plug. Pick one of the black wires and connect it to the NEGATIVE terminal of the battery on the LEFT. Connect the other end to the terminal on the receptacle that matches the BLACK wire on the troller plug. Now use markers to identify each wire so if you disconnect them you know where they go. They will be +24 volts, +12 volts, Jumper, and Ground. Done! Go fishing!
