BoiseBoater
- Jul 24, 2010
- 3
I have a 1991 19' Reinell 190hp. It has a 4.3L OMC Cobra. Owned a boat for 6 years and the Fuel guage hasn't worked since I bought it so I finally did a "fuel study" last weekend to help me better estimate my fuel situation. Was wondering what other people get for mileage. I had heard that this OMC motor was pretty good for mileage. I realize there's a HUGE difference if you're mostly WOT or if you're hanging out alot without the motor running. We spent about 11-12 hours on the boat that weekend. A couple hours of hard water skiing, tubing, etc. Another couple hours of "cruising the lake" at higher speeds. Half the time was probably "hard time" and the other half was idle, no engine running, etc. Probably a pretty typical way my boating time is spent.
When I went to fuel up the next weekend, it took 14 gallons. Therefore, it was about 1.2 gallons per hour spent on the boat. Again, I realize this could swing dramatically depending on the throttle usage. The tank is (I think) about 26 gallons. So I should be able to get about 20 hours of boating per tank. At $3/gallon, that would be $78/tank and about $4/hour to run the boat(gas expense only of course!).
Curious if others could estimate their "gallons per hour" usage.
