How to troubleshoot ignition problem
jspringator
My 89 Bayliner was climbing onto plane when the motor suddenly died. Would not re-start. I'm guessing ignition problem. It turns over but won't catch.
I know enough to check the kill switch, but what else do I check? I was pretty high up, so something could have slid backwards and hit something causing the problem.
I have an extra keyed ignition switch. Should I try that? Is it fused? I failed to check if the gauges came on with the ignition switch on.
Any suggestions will be welcome. My boat is 2 hours away, so I want to be prepared when I go down there.
Don S
Re: How to troubleshoot ignition problem
Click here, and have a look at item 17.
jspringator
Does anybody know where the wiring plug to the engine is on the OMC 5.8L? I'm thinking a sliding battery box knocked something loose.
jspringator
Boy was I wrong! The base of the spin on fuel filter (where the rubber seal meets the filter body) was corroded, breaking the seal, causing the fuel system to suck air. What a bizarre issue.
