jmcardamone
- Aug 6, 2010
- 19
Good evening all,
I present my question to you knoweldgeable folks as i have read just about every thread imaginable Throughout Iboats and Im just plain stuck. Here's my Delimma...
Got a 1987 evinrude 110 HP V4 Enigne. I just bought the boat and the engine will not open up past 2,500 RPM. Ive done the following...
Starting from the boat...
Checked the Anti Siphon valve
Replaced the Fuel line from boat to Motor with new line and Bulb (and i checked the valves, they are good)
Replaced the Quick disconnects (hose and motor)
replaced Hoses from Quick disconnects to Fuel Filter
Replaced Filter
Replaced Hoses from Filter to Pump
(Mine is a VRO Pump, VRO removed and Nipple on fuel pump capped)
Replaced hose From pump to Carbs including intermediate lines and tree
Replaced hose from Filter to Engine (the pulser or something??)
Removed, Cleaned and rebuilt the carbs. (the carbs were squeaky clean when i started but i did the gambit anyway. All Orfices are Clean and Air/Cleaner flows well)
Replaced Stator and Timing ring
Replaced Spark Plugs with the Correct champions
Replaced spark plug wires
checked all the connections.
Removed the Oil level sensor, Oil Pump Sensor, and both bank temp sensors from the warning horn loop (to possibly disable slow)
After all of this, she Idles Well, Runs at 2,500 with no spits or sputters, and seems strong. I have compression across all 4 cyls' (between 100-and 110 across all 4)
what she does present with is this...
Intermittent Tach - the tach will work when it wants to.... Might be a wiring issue under the dash but could be something with the pulse
when on muffs she idles at 2,000.. when in water she idles at 1,100..
when Placing into forward gear rpms drop really low. its a crapshoot if the engine recovers or if i need to restart
I feel like its running in SLOW mode but the wiring diagram i have dosent show the SLOW system ever getting to the packs or the modules.
So at this point my next thought is to replace the 2 CD packs, the Rectifier, and the Module. Outside of those, WTF else could it be? Could a weak coil do this?
I am open to any and all suggestions....Including trading it in for a merc!
Thank you all for reading and I hope i can return the favor in the future.
Joe
Replaced Filter
Joe
