ok here is what happened...took the boat out on the 4 of july and it ran great..got it home and was going to do some maintance and so i changed the fuel filter..lower unit oil and new plugs....took it to the lake today and when i put it in the water and cranked it and i get the beep beep beep after it runs fro about 10 seconds....i guess what im asking is changing the fuel filter will it set off the alarm....also when looking at the bottom front of the motor with the cal off i see a lilttle red light come on when the beeping starts ...is there something i need to do after changing the fuel filter.....o yea i have already put it on another tank that is a 50-1 mix ....i thought it was an oil problem but not sure ...thanks
