I am going to be converting my 5.7 OMC engine to electronic IGN.
I know I need a new ESA module that is compatible with electronic IGN, and a new distributor and coil.
Is it correct that if I get the new ESA module that is compatible with electronic IGN that I dont have to do the resistor box thing mod that has been talked about on here?
Any of you done it? What dist and module did you use?
Can anyone tell me a good combo that will work good (dist, coil, and ESA)?
Also when I look at ESA's online all I see is a little module with wires coming out of it with connectors. Is that all it is? Its not the little rocker arm that gets engaged when you shift?
Thanks so much
Thanks so much
