Re: 1970 Tri-Hull. New to Boating: Lot's of water draining.
need more info.
im guessing this is an outboard.
first thing to do, is get on a creeper and crawl the length of your boat, look for any hull penetration spots, look on the keel and the chines/strakes.
failing finding any damage.
take the boat out on a calm day and put around for an hour, dont hit any big waves, just putt.
look for water in the bilge.....yes=leak
if you see no water after an hour, then circle hard at medium throttle, do this a few times, both left and right.
water getting in= seperation in the cap at the bow rail. re caulk the rub rail seam.
no water?
do full throttle stop and starts, look for water coming over the back when the stern wave hits you,
water ?= re distribute weight to the bow
no water ?...post back here.
cheers
oops
