I recently bought a 1973 chrysler boat with a 1972 (707HE) 70 hp chrysler motor attached to it. The p/o said it ran last year - sort of! Compression is 130 lbs on all 3 cylinders. Carbs are clean. It has good spark, starts quick and idles smooth. I took it out to the lake yesterday and once it is put under load it stumbles, bogs, sighs and dies! I took the cowl off in the middle of the lake attempting to determine the cause of problem and concluded its an ignition problem with the timing advance, or some type of safety switch - somewhere. Here's why: I got my wife to sit behind the wheel and put the motor in gear, but not throttle it up. I sat on the back and grabbed the throttle linkage and opened it up - wide open. It ran fantastic and according to the almost 40 year old speedo was actually doing 35 mph!! I was able to repeat this time and time again, but as soon as I tried wot with the control, it would stumble, bog, spit and die. I am not too familiar with outboard electrics, but it seems as though there is something preventing the motor from opening up under wot with the control column - perhaps a faulty rev limiter or safety switch or??? Has anyone had a similar situation, or perhaps some advice on where to start looking?
Thanks -- Al
Thanks -- Al
