Re: 1975 75HP Evinrude Engine spurts
what lake, and whereabouts on the lake were you? (makes no difference, I'm just curious).
What plugs you running? If they're in good condition, changing 'em won't help.
Hit it at high speed? no prop damage...did the motor kick up, or just suddenly stop running? I'm wondering was it a prop strike, or did it just hit the lower unit?
It's a "flywheel key", #13 in the diagram below. (
www.shop.evinrude.com click on "electronic parts catalogues", drill down to your year/hp/model.)
Spark timing is controlled by sensors in the flywheel, so it has to maintain its orientation to the crankshaft. If the key shears, flywheel spins on the crank, the timing gets screwed.
It's a likely candidate, but before ya go yanking the flywheel off, check the compression first, it might reveal whether the engine suffered any internal damage. Do a spark test, too. If you got good spark on all three, makes a timing problem seem more likely.
you'll need a gear puller, torque wrench, inductive timing light, and a shop manual (highly recommend the factory shop manual).
Not the kind of puller that grips it by the edge (flywheel will break), it needs to have three bolts that screw into the threaded holes in the flywheel. Believe those are 1/4-20 but check first to be sure. You can use those same holes to bolt a piece of wood or bar stock or something to hold the flywheel while you remove/reinstall the flywheel nut. It must be torqued to spec (100 ft lbs) else the key will shear again.
Afterward you have to reset the TDC pointer and set the timing. When you get ready to set the WOT timing, go to the "engine FAQ" section and look for the Joe Reeves thread on Setting WOT Timing at Cranking Speed. You won't find that information in any manual.
factory manuals available at
www.kencook.com or
www.marineengine.com little pieces parts like that (gaskets/orings/hardware, chemicals like OMC Gasket Sealant, etc. not available on iboats), you can order from BRP at that evinrude website, or I use
www.ishopmarine.com sometimes...lower prices but higher shipping & handling.
Keep us posted.
