4.3 V6 190HP RUNS BUT POPS-DIAGNOSIS WANTED
papaki63
AFTER LAST SERVICE OF A4.3 V6 190HP YEAR 1990 I/O MERCRUISER AND THE USE OF WRONG SPARK PLAGS (LONGER) THE ENGINE STARTED POPING FROM CARBIRATOR.<br />DAMAGE DIAGNOSIS WANTED.<br />REPAIR INSTRUCTIONS ALSO.
akriverrat
Re: 4.3 V6 190HP RUNS BUT POPS-DIAGNOSIS WANTED
compression check to rule out intake valve damage if popping through carb. lean mixture also a possibility.
Ditto.......<br />And Loose the CAP-LOCK.......
denniz
id check your firing order for a crossed spark plug wire. didnt pop before plugs? added plugs and now pops.... Darn sure worth checking
