I have a '91 Evinrude 150 xp that usually runs flawlessly, but occasionally without warning, it bogs out when trying to plane off.
It never stalls out when this happens, and if I back off the throttle and try again, it will eventually achieve plane, mildly surging for a few seconds, and then "BINGO" everything is fine again.
I've read up on the VRO pump and believe it's working fine. I've also checked all lines and connections to and from it. I've changed out the fuel filter, changed plugs, run gas treatment, etc.
Does this sound like a possible carb problem, as I have not got to those yet?
Any advice would be well appreciated,
Thanks.
Thanks.
