New here. I have a 97 Mercury 115 that recently went low on 2-stroke oil. After refilling, it went through a couple engine shutdowns after about 45 seconds. It finally started running correctly but now appears to be low on power. Any ideas to check?
Thanks, guys. Checked compression and all were at 135 psi, plugs looked very good as well. In the process of pulling the plugs, the #4 wire was disconnected at the coil. I'll put it back in the water this week and run it.
