Pontoo-n boat
- Aug 4, 2010
- 1
I'm having an issue with a 2007 Honda 50hp 4 stroke. It maybe has 20 hrs on it. Starting is a little rough and has to idle @ 2100 rpms for a few min. It runs great at full throttle. However when pulling the throttle back to idle (prop still engaged) for taxing to the dock, it dies or runs rough. This is very fustrating when I'm tring to go from fwd to rev and the darn thing dies. I've put a new fuel filter on and run fuel treatment every time I fill it up. Could this be a valve adjustment? Or a carb adjustment? I bought it used and the guy said that I would be very pleased with the preformance, which I am but.... it is very fustraiting when I'm trying to come in to dock and it dies. Forgot to add, after it's warmed up good and the prop is NOT engaged it purrrrrs very nice. it's just when I put it into gear is when it dies. What I've been doing is starting it in neutral @ high idle and then jumping it into gear, however I'm afraid this might cause damage to the lower unit. Any suggestions? Thanks
