on a mercruiser 4cylinder i/o, what and where is coupler? thanks
P potatoe Petty Officer 3rd Class Joined May 27, 2010 Messages 77 Aug 4, 2010 #1 on a mercruiser 4cylinder i/o, what and where is coupler? thanks
D Doernuth Petty Officer 1st Class Joined Jul 6, 2010 Messages 332 Aug 4, 2010 #2 Re: where is coupler located? The coupler is bolted to the engine flywheel and is where the shaft from the outdrive is inserted. You must pull the drive and the engine to get to it, but you may be able to inspect it by just removing the drive.
