brogantynan
- Aug 3, 2010
- 2
godfrey pontoon beeping under dash when running seems to run fine
Very good advise..... Don't run the engine till you see what beep you are having. i hope its only a water pump problem which is an easy fix.....
This is engine related and not boat related. Look in your engine manual to determine the cause of the beeps. If you don't have a manual, contact a local marina or the engine manufacturer.
The beep is typically an indicator of overheating or low oil. Don't run the engine again utill you have resolved the problem.
No reason to let it run to low
Unless you count absentmindedness, which occasionally afflicts the best of us. I always keep a gallon of Quicksilver two stroke in the boat and have found myself adding it on the water more than once.
