Johnson 150 hp Ocean Pro 2000 Trim/Tilt motor
Richard 57
When I lower the motor it makes a wear noise. As I lower it it jerks up and down. I was told to raise it and leave it an hour to minimize bubbles. Then to add fluid to it. I did it and everything work well for a couple of days. Now it started again. Some guy told me I have to bleed the air bubbles like when you do a brake job. Well I did not find a bleeding valve nor could find anything related in the service manual. Can somebody give me some advice in how to repair it. Thanks in advance!!
jonesg
Re: Johnson 150 hp Ocean Pro 2000 Trim/Tilt motor
Like power steering in your car its self bleeding if you operate it from one extreme (up) to the other(down). Top up with fluid. Do it a few times.
tashasdaddy
Tilt motor all the way up and lock it there, open , fill, close. Unlock, lower motor all the way down. Now back up, lock, fill, close, lower. Repeat, repeat, repeat..
Use Dextrin II auto trans fluid, or power steering fluid.
