Re: 86 Four Winns 190 Prop Help
I just purchased an 86 Four Winns 190 Horizon, with a 4.3L 2bbl / alpha drive. The prop is gone, so I do not have a reference to start from. The marina thought that it originally would have come with a 14 1/2" dia 19 or 21 pitch. I am less concerned about top speed and would like to have a better holeshot to pull up a skier. I also can not afford SS, so Al it is. Does anyone have a similar boat that can suggest prop specs that work well for them.
Thanks
ESSENTIAL DATA REQUIRED
When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
