Looking for the correct idle speed timing degree setting for this motor. I can't find a specific reference to this particular year but see several differing setting for years right before and right after this model year.
more facts below:
1988 (#0B269663) 20hp Merc outboard - manual - short shaft.
The carburetor is a WMC type. I think the fact that it has a WMC carb is important but it makes the motor a bit odd in the Repair manual I have used. I would not be surprised if mercury had a service bulletin on this.
One source says 2 deg BTDC for idle timing
Another source says 2 deg ATDC for idle timing
Other manuals that don't specify the exact year give me other settings.
Does anyone know for sure what the timing is for this year (1988) motor ?
Thanks so much if you can give me the info !
more facts below:
