trim problems
gary54
I have a 115 hp motor and when I trim up the motor it slows down and seems to start missing or running bad,the motor runs fine until I trim it up to where it normally runs,I have tryed 2 differnt props and it does it with both
gary54
Re: trim problems
I have a 115 hp motor and when I trim up the motor it slows down and seems to start missing or running bad,the motor runs fine until I trim it up to where it normally runs,I have tryed 2 props and it does it with both[ is there a problem with rpm or is this a prop problem,I am using the same prop that I have never had problems with /QUOTE]
emdsapmgr
Re: trim problems
Check the fluid level in the power trim reservoir.
honda400ex2003
Re: trim problems
I am wondering if you have a good way to get fluid into the res on them since the hole is out the side. I was having some trouble with it in the lake so i was thinking of taking my hurricane out and driving it down the ramp forward to get enough of a slope. I hope i didnt entrude on your thread, i didnt want to start a new one on a close topic. Mine stays running fine, it just falls down after 10 minutes or so. it is a evinrude ficht 115. Any help would be great, thanks steve
