Hello again,
sorry for the multi posts on this engine. Couldn't find anything on this topic in the search feature.
I had her hooked up to the pipe after installing the oiler block off kit this morning, and had a solid 15 minutes of idle time. after assuring things were looking ok, the engine was sounding right, and the impellar was continuing to do it's job, I decided to vvvrrrreeeep, the throttle one time. What i noticed was an almost "four-stoke" like throttle response. Not what I expected from the two stroke at all. It really seems that the response was "lazy / slow". I'm thinking a link and sync may be in order? I have my original set-up manual, and the original maitnence manual, but couldn't find anything on link and sync. Just curious if someone could give me the run down on this procedure or if it sounds like this could be my problem. Maybe a timing issue? Just not the response I get from the Evinrude looper 150. It is running wide Open as soon as i tap the throttle. The Merc Just slowly creeps up in rpms, not the instantaneous jump that I would expect. . .
Is the engine running properly? I may just be used to something different.
Welcoming advice.
J Hartman
Welcoming advice.
J Hartman
