Re: Over heating horn
I keep getting a overheating buzzer on my 1991 175 Evinrude. Ive changed the Diverter tubes gaskets, Thermostats, Both sensors, Water pump kit. Now when i go out it starts to sound before i get out the last bouy.has any one experianced this, any help will be apreciated,Thanks.
does the horn shut off on its own eventually?
or do you just deal with it???
or do you turn around and go back in and shut it down?
I ask because I think the horn system can have a flaw,...mine does
the constant horn comes on exactly 2 minutes after I turn the motor on...EVERY SINGLE time..and it sounds for exactly 10 seconds...then goes off, ....till i shut the motor down and when i start it back up the whole things happens again at the same interval....but the motor is running good...
I am thinking of just putting some sound proffing on the horn to knock the volume down some...
I know i go out the harbor and every marina that hears it is think
Ha ha ha, that idiot is about to ruin his motor.....
bob
