Master Mate Mike
- Jan 3, 2008
- 7
Hey Guys
The past couple of trips to the lake I've run into a problem with the outdrive.
I've got a 1987 Sea Sprite with the OMC 3.0 liter and Cobra
outdrive.
After the engine is warmed up and I've been tooling around a while (about
an hour), I'll go to throttle up and the engine comes to life
and and boats starts to take off, but only to have the drive/engine "slip", like a car's transmission slipping out of gear.
I bring the throttle back and then re-do the manuever, same thing- as the
engine RPM's pick up and the boat starts to take off, it seemingly slips out of gear and the RPM's go thru the roof until I bring the throttle back to neutral.
Only way to get it back to the dock is to engage forward but slightly above idle so as to make a little headway.
So I'm thinking it's more complicated than a linkage issue....my usual
bad luck dictates it be something more sinister....
If anyone can relate to the issue or give me some ideas on a fix, I'd be forever grateful.
Thanks
Mike
outdrive.
Thanks
Mike
