FWGarrison
- Jul 6, 2003
- 3
This is my first post so I will try not to write a novel. <br />The leading particulars are;<br />I/O 3.0L Mercrusier Model Number OC464636.<br />The problem I am having is hard starting, rough idle and hesitation during acceleration. WOT is at 4200 within specs and it runs great.<br />I have overhauled the Mercarb 2 bbl with a Sierra overhaul kit from West Marine using information from Clymer and Sierra. It had the solid needle set up so I replaced it with the same.<br />The Ignition system has been upgraded with a new Pertronix Ignitor 2 system with a new Accel SuperCoil. There are new plugs, wires, rotor and dist cap installed. I have checked this system and it seems to be working fine.<br />I have adjusted the idle speed and set the timing to the specs as per the Clymer manual.<br />I thought I may have set the float level wrong so I tore the carb down and checked. It was fine. The engine started easy and ran great on the trailer. Once I put it in the water same problem.<br />I suspect the carb since I have pulled the new plugs and am seeing indications of to much fuel.<br />I know I am missing something but I am out of ideas and could use any opinion! I am beginning to think this boat hates water.<br />Thanks in advance
